On 09/10/10 14:42, Ton Voon wrote:
> See my email re: "test failure with latest code". My guess is that
> line referenced in that email is the one causing the problem.
Ah yes, i remember now. I didn't thought its related to this problem.
> I changed the max_parallel_service_checks to 2 and svc2 is still not
> getting rescheduled.
> So can anyone confirm if either the current code:
> * causes breakage or
> * means that the test is now invalid and svc2->next_check should ==
> now
Ok, then i can confirm that current code breaks disabling active host/service checks and the
test is still valid.
Sven
