--========GMX85451232062369969009
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
-------- Original-Nachricht --------
> Datum: Thu, 15 Jan 2009 23:49:43 +0100
> Von: "Wolfgang"
> An: [email protected]
> Betreff: [Nagios-devel] typo in quickstart-ubuntu.html
> I guess it should be "sudo" instead of "sudi"
> Wolfgang
Hi Wolfgang, hi list,
here is a patch for some of the html documentation files. I've created the patch using 'git diff -U3'.
Sorry Wolfgang, I didn't find any occurrences of "sudi" in the html files.
Regards
Bernd
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger
Content-Type: text/x-patch; charset="iso-8859-15"; name="html-doc-patch.diff"
Content-Disposition: attachment; filename="html-doc-patch.diff"
diff --git a/html/docs/monitoring-publicservices.html b/html/docs/monitoring-publicservices.html
index 9a383c3..b275752 100644
--- a/html/docs/monitoring-publicservices.html
+++ b/html/docs/monitoring-publicservices.html
@@ -107,7 +107,7 @@ For each service you want to monitor, you need to define a
-Some example service definitions for monitoring common public service (HTTP, FTP, etc) are given below.
+Some example service definitions for monitoring common public service (HTTP, FTP, etc.) are given below.
@@ -382,7 +382,7 @@ This service definition will monitor the IMAP4 service and generate alerts if th
-A more advanced service definition is shown below. This service will check the IAMP4 service and generate an alert if the server doesn't respond within 5 seconds or if the response from the server doesn't contain "mygreatmailserver.com".
+A more advanced service definition is shown below. This service will check the IMAP4 service and generate an alert if the server doesn't respond within 5 seconds or if the response from the server doesn't contain "mygreatmailserver.com".
@@ -411,4 +411,4 @@ If the verification process produces any errors messages, fix your configuration
\ No newline at end of file
diff --git a/html/docs/notifications.html b/html/docs/notifications.html
index 2753eca..af1a1ab 100644
--- a/html/docs/notifications.html
+++ b/html/docs/notifications.html
@@ -89,7 +89,7 @@ The first filter that notifications must pass is a test of whether or not notifi
-The first filter for host or service notifications is a check to see if the host or service is in a period of scheduled downtime. It it is in a scheduled downtime, no one gets notified. If it isn't in a period of downtime, it gets passed on to the next filter. As a side note, notifications for services are suppressed if the host they're associated with is in a period of scheduled downtime.
+The first filter for host or service notifications is a check to see if the host or service is in a period of scheduled downtime. If it is in a scheduled downtime, no one gets notified. If it isn't in a period of downtime, it gets passed on to the next filter. As a side note, notifications for services are suppressed if the host they're associated with is in a period of scheduled downtime.
@@ -204,4 +204,4 @@ If you want to try out a non-traditional method of notification, you might want
diff --git a/html/docs/upgrading.html b/html/docs/upgrading.html
index 8f7d369..9395489 100644
--- a/html/docs/upgrading.html
+++ b/html/docs/upgrading.html
@@ -97,11 +97,18 @@ make install
-Verify your configuration files and restart Nagios.
+Verify your configuration files. Correct any errors shown here before proceeding with the next step.
+Restart Nagios. Debian/Ubuntu users should use /etc/init.d/nagios restar
...[email truncated]...
