[Nagios-devel] Possibly typos in checkcommands.cfg
In sample-config/temlate-object, services.cfg uses some commands
defined in checkcommands.cfg. But it seems passed argumets of some
commands are not matched between these files. I think
checkcommands.cfg is not updated correctly.
How about this patch?
Index: sample-config/template-object/checkcommands.cfg.in
RCS file: /cvsroot/nagios/nagios/sample-config/template-object/checkcommands.cfg.in,v
retrieving revision 1.2
diff -u -r1.2 checkcommands.cfg.in
--- sample-config/template-object/checkcommands.cfg.in 8 Mar 2002 03:38:36 -0000 1.2
+++ sample-config/template-object/checkcommands.cfg.in 6 Jun 2002 02:16:11 -0000
@@ -106,7 +106,7 @@
# 'check_ping' command definition
command_name check_ping
- command_line $USER1$/check_ping -H $HOSTADDRESS$ -w 10.0,20% -c 100.0,60% -p 5
+ command_line $USER1$/check_ping -H $HOSTADDRESS$ -w $ARG1$ -c $ARG2$ -p 5
@@ -127,7 +127,7 @@
# 'check_local_disk' command definition
command_name check_local_disk
- command_line $USER1$/check_disk -w 20% -c 10% -p $ARG1$
+ command_line $USER1$/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
@@ -141,7 +141,7 @@
# 'check_local_procs' command definition
command_name check_local_procs
- command_line $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
+ command_line $USER1$/check_procs -w $ARG1$ -c $ARG2$
Jun Kuriyama // IMG SRC, Inc.
// FreeBSD Project
