------=_NextPart_000_031F_01C65CBB.36360EF0
Content-Type: text/plain;
charset="us-ascii"
Hi Ethan,
i saw that since nrpe-2.4 the call to read_config_file was moved at two
places coming after the ssl initialization code. You remember my patch
introducing the allow_weak_random_seed option? I just compiled nrpe-2.5.1 on
a hp-ux 11.00 server which, according to it's patchlevel has no /dev/*random
and therefore needs this option to successfully complete the ssl handshake.
The problem is, at the time of the ssl initialization,
allow_weak_random_seed is still 0, because the config file has not been read
in yet. Is there a reason, why the config file is opened now later? Of not,
i beg you to apply my patch, which moves config file reading back to the
beginning.
Greetings from Munich,
Gerhard
Content-Type: application/octet-stream;
name="nrpe-2.5.1.first.readconfig.patch"
filename="nrpe-2.5.1.first.readconfig.patch"
diff -Naur nrpe-2.5.1/src/nrpe.c nrpe-2.5.1.first.readconfig/src/nrpe.c=0A=
--- nrpe-2.5.1/src/nrpe.c 2006-04-10 03:42:30.000000000 +0200=0A=
+++ nrpe-2.5.1.first.readconfig/src/nrpe.c 2006-04-10 16:03:59.768625700 =
+0200=0A=
@@ -175,6 +175,15 @@=0A=
config_file[sizeof(config_file)-1]=3D'\x0';=0A=
}=0A=
=0A=
+ /* read the config file */=0A=
+ result=3Dread_config_file(config_file); =0A=
+=0A=
+ /* exit if there are errors... */=0A=
+ if(result=3D=3DERROR){=0A=
+ syslog(LOG_ERR,"Config file '%s' contained errors, bailing =
out...",config_file);=0A=
+ return STATE_CRITICAL;=0A=
+ }=0A=
+=0A=
/* generate the CRC 32 table */=0A=
generate_crc32_table();=0A=
=0A=
@@ -235,15 +244,6 @@=0A=
/* if we're running under inetd... */=0A=
if(use_inetd=3D=3DTRUE){=0A=
=0A=
- /* read the config file */=0A=
- result=3Dread_config_file(config_file); =0A=
-=0A=
- /* exit if there are errors... */=0A=
- if(result=3D=3DERROR){=0A=
- syslog(LOG_ERR,"Config file '%s' contained errors, bailing =
- return STATE_CRITICAL;=0A=
- }=0A=
-=0A=
/* make sure we're not root */=0A=
check_privileges();=0A=
=0A=
@@ -282,15 +282,6 @@=0A=
/* log info to syslog facility */=0A=
syslog(LOG_NOTICE,"Starting up daemon");=0A=
=0A=
-=0A=
- }=0A=
-=0A=
/* write pid file */=0A=
if(write_pid_file()=3D=3DERROR)=0A=
------=_NextPart_000_031F_01C65CBB.36360EF0--
