Re: [Nagios-devel] Mass define servicedependency for NRPE services
--------------060804050604020003070004
Content-Transfer-Encoding: 8bit
On 9/2/09 8:57 AM, Thomas Guyot-Sionnest wrote:
> Mathieu Gagné wrote:
>> Hi,
>>> Just add the host_name or hostgroup_name directive (you can put all
>>> hostgroups for instance, or enable wildcards and use *) and you're set.
>> Unfortunately, it doesn't work. This explains why I asked the
>> mailinglist. If I do as you suggested, all NRPE based services will be
>> depending on the NRPE service on ALL hosts. (not only their respective host)
>> Here is my servicedependency definition:
>> define servicedependency {
>> hostgroup_name hosts-with-nrpe
>> service_description NRPE
>> dependent_servicegroup_name nrpe-services
>> execution_failure_criteria n
>> notification_failure_criteria c,u
> And what result you get with that? I have pretty much the same, but with
> a "dependent_service_name" directive, and it should do the same. If it
> don't, it's a bug.
So I guess it's a bug or it wasn't initially planned to work that way.
You will find attached to this message a patch against Nagios 3.0.6 that
should fix this bug.
This servicedependency definition should now work:
You shouldn't get those errors anymore at startup:
Error: NULL master service description/host name in service dependency
definition
Error: Could not register service execution dependency (config file
'/etc/nagios3/XXXXX.cfg', starting on line YY)
For all services found in servicegroup "nrpe-services", a
servicedependency against the NRPE service of their respective host
should now be defined for each of them.
Any opinion about it? Is it the proper way to do it?
Mathieu
Content-Type: text/plain; x-mac-type="0"; x-mac-creator="0";
name="nagios-same-host-servicedependencies-with-servicegroups.patch"
filename*0="nagios-same-host-servicedependencies-with-servicegroups.patc";
filename*1="h"
diff -Naur nagios-3.0.6-orig/xdata/xodtemplate.c nagios-3.0.6/xdata/xodtemplate.c
--- nagios-3.0.6-orig/xdata/xodtemplate.c 2009-09-02 17:15:52.000000000 -0400
+++ nagios-3.0.6/xdata/xodtemplate.c 2009-09-02 17:21:55.000000000 -0400
@@ -5247,6 +5247,7 @@
char *service_descriptions=NULL;
int first_item=FALSE;
+ int same_host_servicedependency=FALSE;
@@ -5725,6 +5726,11 @@
my_free(temp_servicedependency->dependent_service_description);
my_free(temp_servicedependency->dependent_hostgroup_name);
+ /* MG(20090902): Same host servicegroups dependencies */
+ same_host_same_host_servicedependency=FALSE;
+ if(temp_servicedependency->host_name==NULL && temp_servicedependency->hostgroup_name==NULL)
+ same_host_servicedependency=TRUE;
/* duplicate service dependency entries */
first_item=TRUE;
@@ -5742,6 +5748,10 @@
temp_servicedependency->dependent_service_description=(char *)strdup(temp_dependentservice->name2);
+ if(same_host_servicedependency==TRUE)
+ temp_servicedependency->host_name=(char *)strdup(temp_dependentservice->name1);
/* clear the dependent servicegroup */
temp_servicedependency->have_dependent_servicegroup_name=FALSE;
@@ -5757,7 +5767,11 @@
/* duplicate service dependency definition */
- result=xodtemplate_duplicate_servicedependency(temp_servicedependency,temp_servicedependency->host_name,temp_servicedependency->service_description,NULL,NULL,temp_dependentservice->name1,temp_dependentservice->name2,NULL,NULL);
...[email truncated]...
