Re: [Nagios-devel] Segmentation Fault
Carlos Vicente wrote:
> Hi,
> I just wanted to report a possible bug in the code that pre-checks the
> configuration. There was a circular path caused by an incorrect parent
> definition, and I could see the nagios process using up 99% CPU for
> about a minute before segfaulting. I would have expected a more
> graceful failure output than a core dump. ;-)
> Here's the output. I can send the core file off the list if anyone
> wants it.
A backtrace would be more useful, provided you haven't stripped the
binary, or better yet the configuration so this can be included in
regression tests.
gdb -c core
(gdb) bt
(gdb) quit
> cv
> # bin/nagios -v etc/nagios.cfg
> Nagios 2.0b3
> Copyright (c) 1999-2005 Ethan Galstad (www.nagios.org)
> Last Modified: 04-03-2005
> License: GPL
> Reading configuration data...
> Running pre-flight check on configuration data...
> Checking services...
> Checked 3241 services.
> Checking hosts...
> Checked 1595 hosts.
> Checking host groups...
> Checked 104 host groups.
> Checking service groups...
> Checked 13 service groups.
> Checking contacts...
> Checked 61 contacts.
> Checking contact groups...
> Checked 26 contact groups.
> Checking service escalations...
> Checked 1587 service escalations.
> Checking service dependencies...
> Checked 0 service dependencies.
> Checking host escalations...
> Checked 1564 host escalations.
> Checking host dependencies...
> Checked 0 host dependencies.
> Checking commands...
> Checked 46 commands.
> Checking time periods...
> Checked 9 time periods.
> Checking extended host info definitions...
> Checked 0 extended host info definitions.
> Checking extended service info definitions...
> Checked 1566 extended service info definitions.
> Checking for circular paths between hosts...
> Segmentation fault (core dumped)
> SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
> from IBM. Find simple to follow Roadmaps, straightforward articles,
> informative Webcasts and more! Get everything you need to get up to
> speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
> Nagios-devel mailing list
> [email protected]
OP5 AB www.op5.se
Lead Developer
