Hendrik Bäcker wrote:
> Hi Ethan,
> hi list,
> on the Quickstart Ubuntu Guide there is a mentioned requirement for the
> gd libs like:
> "sudo apt-get install libgd2-dev"
> on an actual Ubuntu 7.10 it should looks like this:
> "sudo apt-get install libgd2-noxpm-dev"
Isn't there a libgd2 with xpm support on ubuntu?
> perhaps the package "libgd2-noxpm" is necessary too.
It is, but unless you've broken your apt-get horribly, or the
Ubuntu packagers are completely incompetent, it will be picked
up as an unconditional dependency of libgd2-noxpm-dev.
OP5 AB www.op5.se
