[Nagios-devel] success compiling NSCA on AIX 5.3 with gcc
It's been way more complicated and weird than I expected, but I got the
send_nsca client to compile on AIX 5.3
First I had to get the prereqs right:
- installed libmcrypt from source (http://mcrypt.sourceforge.net/)
I had to hack the Makefile to remove '-1.7' in a few places for
some reason
- installed Berkley DB (db-3.3.11-4.aix5.1.ppc.rpm) from IBM's Toolbox
for Linux apps
(http://www-03.ibm.com/servers/aix/produ ... nload.html)
- installed tcp_wrappers installp package from
http://www.bullfreeware.com/
When I ran ./configure on AIX, the 'make' broke (see output below). So
then, and this is the spooky part, I ran ./configure on a Linux machine
(RHEL4), and 'make send_nsca' then worked on my AIX machine:
$ make send_nsca
cd ./src/; make send_nsca ; cd ..
gcc -g -O2 -DHAVE_CONFIG_H -o send_nsca send_nsca.c netutils.c
utils.c -lnsl
The binary appears to work fine.
I am ignorant about make/configure stuff, but I think the configure
script is based on really old AIXes and when it sees "aix" it thinks it
should complicate things a lot. But AIX 5L is (deliberately) very
linux-like, especially when it comes to running gcc. One of the goals
for AIX 5L was supposed to be "100% source compatibility with Linux"
Maybe someone who knows more about automake/autoconf could fix the
configure script? I'm happy to test...
-n
nathan vonnahme, system engineer at fairbanks memorial hospital
1650 cowles street, fairbanks alaska 99701. 907-458-5464
$ make send_nsca
gcc -g -O2 -DHAVE_LIBMCRYPT -I/usr/local/include -DHAVE_CONFIG_H
-o send_nsca send_nsca.c netutils.c utils.c -L/usr/local/lib -lmcrypt
-lnsl
In file included from send_nsca.c:20:
../include/netutils.h:37: warning: `struct in_addr' declared inside
parameter list
../include/netutils.h:37: warning: its scope is only this definition or
declaration, which is probably not what you want
send_nsca.c:25: error: syntax error at '@' token
send_nsca.c:25: error: `nsca_port' undeclared here (not in a function)
send_nsca.c: In function `main':
send_nsca.c:102: error: syntax error at '@' token
send_nsca.c:102: error: `nsca_port' undeclared (first use in this
function)
send_nsca.c:102: error: (Each undeclared identifier is reported only
once
send_nsca.c:102: error: for each function it appears in.)
send_nsca.c:200: warning: assignment makes pointer from integer without
a cast
send_nsca.c:205: warning: assignment makes pointer from integer without
a cast
send_nsca.c:210: warning: assignment makes pointer from integer without
a cast
send_nsca.c:215: warning: assignment makes pointer from integer without
a cast
send_nsca.c: In function `read_config_file':
send_nsca.c:495: warning: assignment makes pointer from integer without
a cast
send_nsca.c:504: warning: assignment makes pointer from integer without
a cast
In file included from netutils.c:33:
parameter list
netutils.c: In function `my_connect':
netutils.c:49: error: storage size of `servaddr' isn't known
netutils.c:55: error: `AF_INET' undeclared (first use in this function)
netutils.c:55: error: (Each undeclared identifier is reported only once
netutils.c:55: error: for each function it appears in.)
netutils.c:62: warning: assignment makes pointer from integer without a
cast
netutils.c:68: error: dereferencing pointer to incomplete type
netutils.c:72: warning: assignment makes pointer from integer without a
cast
netutils.c:78: error: `PF_INET' undeclared (first use in this function)
netutils.c:78: error: `SOCK_DGRAM' undeclared (first use in this
function)
netutils.c:78: error: `SOCK_STREAM' undeclared (first use in this
function)
netutils.c:78: error: dereferencing pointer to incomplete type
netutils.c:87: error: `errno' undecl
...[email truncated]...
