[Nagios-devel] [Nagiosplug-devel] Patch for leading whitespace on
--sm4nu43k4a2Rpi4c
Content-Disposition: inline
Hi!
(Sent this to the wrong list initially. Sorry 'bout that)
As of 2.6, Nagios recognizes leading whitespace only in the main
config file. The attached patch fixes this.
To illustrate, this piece of config does not work currently:
define host {
host_name eric.schwarzvogel.de
alias eric.schwarzvogel.de
address 194.97.4.250
#check_command check_host_alive
check_command check_host_new
max_check_attempts 3
retain_status_information 1
contact_groups Privat Klausmann
notification_interval 30
notification_period 24x7
notification_options d,u,r
passive_checks_enabled 1
The reason is the commented-out check_command line. It would work
like this:
define host {
# check_command check_host_alive
This is because (for non-main config files), Nagios first checks
if the first char is "#" and *then* strips the line. For the main
config file, this happens the other way around.
I've attached a patch that makes this behaviour more consistent.
I believe the check for '\0', '\n' etc. could be simplified to,
*if* strip() removes some of the chars. I tried to be
non-invasive as possible, so I didn't do that.
I'd like it if this patch makes it into the 2.x series.
Regards,
Tobias
--sm4nu43k4a2Rpi4c
Content-Disposition: attachment; filename="whitespace_comment_fix.patch"
--- base/config.c.orig 2007-01-19 13:15:52.000000000 +0100
+++ base/config.c 2007-01-19 13:17:00.000000000 +0100
@@ -1518,12 +1518,15 @@
current_line=thefile->current_line;
+ /* Strip line first so that a hash preceded by
+ * only whitespace is treated correctly
+ strip(input);
/* skip blank lines and comments */
if(input[0]=='#' || input[0]=='\x0' || input[0]=='\n' || input[0]=='\r')
continue;
- strip(input);
/* get the variable name */
temp_ptr=my_strtok(input,"=");
--sm4nu43k4a2Rpi4c
Take Surveys. Earn Cash. Influence the Future of IT
Join SourceForge.net's Techsay panel and you'll get the chance to share your
opinions on IT & business topics through brief surveys - and earn cash
http://www.techsay.com/default.php?page ... CID=DEVDEV
--sm4nu43k4a2Rpi4c
_______________________________________________________
Nagios Plugin Development Mailing List [email protected]
Unsubscribe at https://lists.sourceforge.net/lists/lis ... plug-devel
::: Please include plugins version (-v) and OS when reporting any issue.
::: Messages without supporting info will risk being sent to /dev/null
--sm4nu43k4a2Rpi4c--
