> Hi Andreas,
> thanks for your work! We're quite busy so we had no time yet to
> even try out Nagios 4.
> Do you think it would be easily possible to have a common code
> base for N3 and N4 for Livestatus (kind of #ifdef)?
Since most Nagios headers are included from a single place, it
shouldn't be that hard. I'm not sure I'll have time to look into it
before the conference (as I haven't written my presentations yet),
but I'll look into it. Nagios 3 will be default in that case, and
Nagios 4 will have to be enabled explicitly. My autoconf-fu is
pretty weak, but I think I could manage that.
> Also I've seen that you removed some columns that seem to not
> exist in N4. We'd need at least dummy columns here so that
> code relying on that columns will not break.
Good idea. I'll readd them.
Thanks for the feedback
OP5 AB www.op5.se
on peace.
