We actually don't need update_status variable.
OK? Comments?
--- base/commands.c (revision 2021)
+++ base/commands.c (working copy)
@@ -97,7 +97,6 @@
/* checks for the existence of the external command file and processes all commands found in it */
int check_for_external_commands(void) {
char *buffer = NULL;
- int update_status = FALSE;
log_debug_info(DEBUGL_FUNCTIONS, 0, "check_for_external_commands()\n");
@@ -110,11 +109,7 @@
/* update the status log with new program information */
/* go easy on the frequency of this if we're checking often - only update program status every 10 seconds.... */
- if(last_command_check = (last_command_status_update + 10)) {
last_command_status_update = last_command_check;
update_program_status(FALSE);
