Re: [Nagios-devel] Nagios 4: Registering object relationships in
On 8 Jan 2013, at 10:16, Andreas Ericsson wrote:
> On 01/08/2013 10:24 AM, Ton Voon wrote:
>> My original patch, reattached, is not ideal but fixes the problem, so =
I present it as a way to show why the current behaviour is wrong. I'm =
sure there's a better solution, probably some other "do expansion of =
object relationships" call that should be invoked instead, but I can't =
quite understand the C-fu magic that is going on with the new =
configuration code!
>>=20
>=20
> Thanks a lot. I'll get this fixed today.
Hi Andreas,
Have you had a chance to look at this? Alternatively, can you provide =
some pointers to where this might be and what to look out for?
Ton
