Re: [Nagios-devel] New field in service_struct
-------- Original Message --------
Subject: Re: [Nagios-devel] New field in service_struct
To: Andreas Ericsson
Date: 2010-03-23 16:14
> It's very strange because I do a make clean and a make distclean just
> before start compil process.
Andreas is talking about modules - do you have any neb modules like
ndoutils or merlin installed? Then you need to adapt their object.h and
recompile/reinstall too.
If you might have one of those enabled, try to disable them and start
Nagios again in the first place.
Kind regards,
Michael
> Le 23/03/2010 16:04, Andreas Ericsson a écrit :
>> On 03/23/2010 03:02 PM, Samuel Mutel wrote:
>>> Hello,
>>> I want to add in objects.h a field to service_struct so I put after "int
>>> last_state;"
>>> int last_state_before_flapping;
>>> For the moment, I just put this line. When I compil Nagios and after a
>>> notification, the process crash with Program received signal SIGSEGV,
>>> Segmentation fault.
>>> Do you have an idea ?
>> If you're using any kind of eventbroker module that access raw service
>> objects, they will need to be re-compiled or Nagios will crash.
>> If you're re-building without making sure all sources that use the
>> objects.h header file is recompiled (not just re-linked), you'll get
>> a crash.
>> Other than that, I really can't think of anything.
> Download Intel® Parallel Studio Eval
> Try the new software tools for yourself. Speed compiling, find bugs
> proactively, and fine-tune applications for parallel performance.
> See why Intel Parallel Studio got high marks during beta.
> http://p.sf.net/sfu/intel-sw-dev
> Nagios-devel mailing list
> [email protected]
DI (FH) Michael Friedrich
[email protected]
Tel: +43 1 4277 14359
Vienna University Computer Center
Universitaetsstrasse 7 A-1010 Vienna, Austria
