------=_NextPart_000_002B_01C9308C.BD518200
Content-Type: text/plain;
charset="us-ascii"
2) Problem: Nagios 3.0.3 core dumps and slowing down when command/plugin
problems.
Troubleshouting:
With Nagios 3.0.2 no problem.
You can only find the root cause when you launch Nagios manualy at the
command promp like:
/opt/monitoring/nagios/bin/nagios /opt/monitoring/nagios/etc/nagios.cfg
- when nagios have no right to execute the fping command or
- when nagios cannot found /opt/csw/libexec/nagios-plugins/check_fping
a plugin to execute
When nagios runs in deamon mode, you can't sea the problem, yoiu only
see that the deamon
is continuously is restarting and because of this, Nagios when very slow.
Solution:
Instead of crashing, can you make a list af all possible to execute
commands/plugins
and try to execute them during nagios verify.
Then can you also produce a list of all problems related to these
commands/plugins with
the output of the related problems, and mask these command so the are
not executed.
Content-Type: text/html;
charset="us-ascii"
Message
2) Problem: Nagios=20
3.0.3 core dumps and slowing down when =
command/plugin=20
problems.
Troubleshouting:
With Nagios=20
3.0.2 no problem.
You can only find the root cause when =
you launch=20
command promp like:
/opt/monitoring/nagios/bin/nagios=20
- when nagios have no right to execute =
the fping=20
command or
- when nagios cannot found=20
a plugin to execute
When nagios runs in deamon mode, you =
can't sea the=20
problem, yoiu only
see that the deamon
is continuously is restarting and =
because of this,=20
Solution:
Instead of crashing, can you make a =
list af all=20
possible to execute
commands/plugins
and try to execute them during nagios=20
verify.
Then can you also produce a list of all =
problems=20
related to these
the output of the related problems, and =
mask these=20
command so the are
not executed.
------=_NextPart_000_002B_01C9308C.BD518200--
