[Nagios-devel] regarding upcoming features
I was going thru the upcoming features list and had a
couple of questions/comments.
CGI:
Even if the move to Fast CGIs is made, having the CGIs read the object
config files directly would still cause the CGIs to be out of sync with
the running monitor if the monitor was not restarted.
Perhaps a "compiled" config created at the the start by the monitoring
daemon would prevent the out of sync issue.
Adaptive monitoring:
Also if adaptive monitoring get used - some way to write out the running
config would be useful. Otherwise a restart would loose the any changes
made. Of course the argument could be made that one must modify the
configs as well.
-sg
