[Nagios-devel] Found bugs in 1.1
This message is in MIME format. The first part should be readable text,
while the remaining parts are likely unreadable without MIME-aware tools.
Send mail to [email protected] for more info.
--2093892754-818930009-1069444410=:10331
Content-Type: TEXT/PLAIN; charset=US-ASCII
Hash: SHA1
Hello, I've found a few bugs in 1.1 that may be a bit troublesome.
One of them is that the 'notification_period' clause of a host is not
required. I had a template that was missing this clause and several hosts
that used the template. When I tried running a Nagios compiled w/debug
enabled it coredumped when it tried to print out the host definition.
Another is that if a service dependency has neither of the
execution_failure_criteria or notification_failure_criteria defined it is
silently ignored. I think a warning indicating that this 'lame'
servicedependency exists should be thrown; I've attached a patch to effect
this.
A third is that the following causes a coredump; I think the servicedep
duplication function should detect when its trying to set up an
immediately circular depedency.
define servicedependency{
hostgroup_name HOSTGROUP1
service_description Oracle
dependent_hostgroup_name HOSTGROUP1
dependent_service_description *
execution_failure_criteria n
notification_failure_criteria w,u,c
- -Jason Martin
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.3.3 (GNU/Linux)
Comment: pgpenvelope 2.10.2 - http://pgpenvelope.sourceforge.net/
iD8DBQE/vm1Kl2ODWuqVSBMRAoKwAKCCZYLsz8hneU5XbGVZMkJoro0rSACgkewS
ezmdnoSS5vLrJ2OfwENrDHc=
=/gO5
-----END PGP SIGNATURE-----
Content-Type: TEXT/PLAIN; charset=US-ASCII; name="servicedeps.patch"
Content-Transfer-Encoding: BASE64
Content-ID:
Content-Description:
Content-Disposition: attachment; filename="servicedeps.patch"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--2093892754-818930009-1069444410=:10331--
