I've gotta ask...why?
The normal_check_interval IS the number of time units to wait between
checks when a service is in a hard state. When a service is in a soft
state, the retry_interval is used until max_attempts is reached, at
which point it goes into a hard state and back to the normal_check_interval.
What are you trying to do that normal_check_interval doesn't already
give you?
Russell
David Quattlebaum wrote:
>I want to implement a new service definition directive:
> hard_check_interval #
>If present, this specifies the number of "time units" to wait before scheduling the next check for the service when the service is in the HARD_STATE. If this directive is not given, normal_check_interval will be used for its setting.
>When a service is in the HARD state, I want it to be checked more often.
>Has anyone done this? Recommended this?
>I've started making changes to the source code (nagios-1.1) to see if I can get this to work. It's to the point where the config directive is recognized in the config files. When I choose "View Config" from the left pane of the nagios web page and choose the "Services" object type, it shows the "hard check time" column filled in correctly.
>I just can't figure out where to change the code to make it work. The files I've changed so far are:
>base/nagios.c - at line 1542, I check for HARD_STATE and used hard_interval
> instead of normal_check_interval. I thought this would make it
> work, but was wrong.
>cgi/config.c - show hard_check_interval on web page
>common/objects.c - added hard_interval to add_service(). use normal_interval if
> hard_interval
>common/objects.h - added hard_interval to add_service() proto.
>xdata/xodtemplate.h - added hard_check_interval (and have_hard_check_interval) to
> xodtemplate_service
>xdata/xodtemplate.c - process hard_check_interval
>Thanks for any help.
>David Quattlebaum
>"Weebles wobble but they don't fall down."
>This SF.NET email is sponsored by: eBay
>Great deals on office technology -- on eBay now! Click here:
>http://adfarm.mediaplex.com/ad/ck/711-11697-6916-5
>_______________________________________________
>Nagios-devel mailing list
>[email protected]
>https://lists.sourceforge.net/lists/lis ... gios-devel
Russell Scibetti
Quadrix Solutions, Inc.
http://www.quadrix.com
(732) 235-2335, ext. 7038
