Hendrik Bäcker wrote:
> Hi,
> Alessandro Ren schrieb:
>> I got the latency to stabilize disabling the
>> process_performance_data in nagios.cfg. Enabling it again cause the
>> latency do start to go up.
>> Any know bug in this part do the code?
>> About the performance data, does it affect the nagios latency?
>> What I mean is, does nagios starts another thread to deal with
>> performance data or it waits for the data to get processed by the
>> external command before returning, thus adding to the service check
>> latency?
>> Thanks.
> I think you are executing the perfdata command after every service
> check (on the fly) ?
> If this should be true than I can imagine of performance problems.
> 1 action to start a plugin
> 1 action to reap the output
> 1 action to handle perfdata
> per service... ouch.
> What addon are you using to handle performance data?
> Hendrik
I am using perfparse to handle performance data writing realtime to
the database, but the strange thing is the latency that keeps going up.
This does not happen in the nagios 2.x.
[]s.
