Re: [Nagios-devel] Nagios 4 ignores object_cache_file and log_file
On 09/16/2012 05:13 PM, Joerg Linge wrote:
> Am 16.09.2012 um 16:27 schrieb Andreas Ericsson :
>> Well, that's by design. The objects.cache should only be written to once.
>> Or do you mean that it gets created but is empty?
> Correct.
> object_cache_file was created using the wrong path (/usr/local/nagios/var/objects.cache as defined in includes/locations.h instead of /omd/sites/ng4/var/nagios/objects.cache defined in nagios.cfg )
> But the file contains just the header.
Righto. I figured it out and a fix is pushed to both github and to
svn. Thanks for helping out.
OP5 AB www.op5.se
on peace.
