Re: [Nagios-devel] sugested update for location.h.in
On Wed, Oct 13, 2010 at 9:47 PM, Marcel J.E. Mol wrote:
> Hello,
> My first post to the list... I just started playing with nagios and doing
> some test developments. For this I need the location of the directory
> where all config files reside. I noticed that all config files are define=
d
> with absolute paths and the config directory itself is not defined.
> It like to suggest a change to location.h.in so I can define new config
> files within a single source file without needing to update other nagios
> core files. =A0The patch is attached. It just adds a DEFAULT_CONFIG_DIR
> define to location.h.in.
The default value for that macro would cause Nagios to recursively search
all of /etc for files ending with .cfg.
Try the cfg_dir option in nagios.cfg instead. It should do roughly what you
want.
--=20
Andreas Ericsson=A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0=A0 andreas.ericsson@op5=
.se
OP5 AB=A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0=A0 www.op5.se
Tel: +46 8-230225=A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 Fax: +46 8-230231
on peace.
