[PATCH] Clean up loads of compiler warnings
--rJwd6BRFiFCcLxzm
Content-Type: multipart/mixed; boundary="WIyZ46R2i8wDzkSu"
Content-Disposition: inline
--WIyZ46R2i8wDzkSu
Hi there,
While looking around the source to get familiar, I rebuilt with -Wall
and noticed lots of compiler warnings. These should all be pretty safe.
Cheers,
--=20
| Stephen Gran | does your DRESSING ROOM have enough |
| [email protected] | ASPARAGUS? |
| http://www.lobefin.net/~steve | |
--WIyZ46R2i8wDzkSu
Content-Type: text/x-diff; charset=us-ascii
filename="0001-Clean-up-loads-of-compiler-warnings.patch"
=46rom d4d6938fb214067de49b72263a4f0b75e8e93586 Mon Sep 17 00:00:00 2001
=46rom: Stephen Gran
Date: Mon, 20 Sep 2010 09:59:52 +0100
Subject: [PATCH] Clean up loads of compiler warnings
Signed-off-by: Stephen Gran
base/broker.c | 4 ++--
base/checks.c | 1 -
base/nagiostats.c | 3 +--
base/utils.c | 9 ++-------
cgi/cgiauth.c | 1 -
cgi/cmd.c | 23 +++++++++++++++++++++--
cgi/extcmd_list.c | 1 -
cgi/status.c | 1 -
common/macros.c | 12 ++++++------
common/objects.c | 3 ---
xdata/xsddefault.c | 1 -
11 files changed, 32 insertions(+), 27 deletions(-)
diff --git a/base/broker.c b/base/broker.c
index 8c0bdd2..b90c79b 100644
--- a/base/broker.c
+++ b/base/broker.c
@@ -184,10 +184,10 @@ int broker_event_handler(int type, int flags, int att=
r, int eventhandler_type, v
int return_code=3DOK;
=20
if(!(event_broker_options & BROKER_EVENT_HANDLERS))
- return;
+ return return_code;
=09
if(data=3D=3DNULL)
- return;
=20
/* get command name/args */
if(cmd!=3DNULL){
diff --git a/base/checks.c b/base/checks.c
index 26bf5c2..f29d01f 100644
--- a/base/checks.c
+++ b/base/checks.c
@@ -134,7 +134,6 @@ int reap_check_results(void){
check_result *queued_check_result=3DNULL;
service *temp_service=3DNULL;
host *temp_host=3DNULL;
- char *temp_buffer=3DNULL;
time_t current_time=3D0L;
time_t reaper_start_time=3D0L;
int reaped_checks=3D0;
diff --git a/base/nagiostats.c b/base/nagiostats.c
index bf7e608..e144267 100644
--- a/base/nagiostats.c
+++ b/base/nagiostats.c
@@ -206,6 +206,7 @@ int read_config_file(void);
int read_status_file(void);
void strip(char *);
void get_time_breakdown(unsigned long,int *,int *,int *,int *);
+int read_nagiostats_file(void);
=20
=20
int main(int argc, char **argv){
@@ -1380,12 +1381,10 @@ int read_status_file(void){
int read_nagiostats_file(void){
char temp_buffer[MAX_INPUT_BUFFER];
FILE *fp=3DNULL;
- int data_type=3DSTATUS_NO_DATA;
char *var=3DNULL;
char *val=3DNULL;
char *temp_ptr=3DNULL;
time_t current_time;
- unsigned long time_difference=3D0L;
=20
time(&current_time);
=20
diff --git a/base/utils.c b/base/utils.c
index a2fd575..429178e 100644
--- a/base/utils.c
+++ b/base/utils.c
@@ -2369,7 +2369,6 @@ int process_check_result_queue(char *dirname){
/* reads check result(s) from a file */
int process_check_result_file(char *fname){
mmapfile *thefile=3DNULL;
char *input=3DNULL;
char *var=3DNULL;
char *val=3DNULL;
@@ -2831,7 +2830,7 @@ int parse_check_output(char *buf, char **short_output=
, char **long_output, char
/* save long output */
if(long_output && (db1.buf && strcmp(db1.buf,""))){
=20
- if(escape_newlines=3D=3DFALSE)
+ if(escape_newlines_please=3D=3DFALSE)
*long_output=3D(char *)strdup(db1.buf);
=20
else{
@@ -3291,11 +3290,7 @@ int compare_hashdata(const char *val1a, const char *=
val1b, const char *val2a, co
=20
/* renames a file - works across filesystems (Mike Wiacek) */
int my_rename(char *source, char *dest){
- char buffer[MAX_INPUT_BUFFER]=3D{0};
int rename_result=3
...[email truncated]...
