------=_NextPart_000_0223_01C69B8A.45038AD0
Content-Type: text/plain;
charset="us-ascii"
(gdb) run -v /etc/nagios/nagios.cfg
Starting program: /usr/src/nagios-2.4/base/nagios -v /etc/nagios/nagios.cfg
[Thread debugging using libthread_db enabled]
[New Thread 16384 (LWP 26363)]
Nagios 2.4
Copyright (c) 1999-2006 Ethan Galstad (http://www.nagios.org)
Last Modified: 05-31-2006
License: GPL
Reading configuration data...
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 16384 (LWP 26363)]
0xb7ebcf34 in strcmp () from /lib/libc.so.6
(gdb) bt
#0 0xb7ebcf34 in strcmp () from /lib/libc.so.6
#1 0x080a0aca in xodtemplate_compare_strings2 (string1a=0x81f1898
"mia.mdcprod.com", string1b=0x81f18c8 "Load", string2a=0x81ec8d8
"mia.mdcprod.com",
string2b=0x6e616973 ) at
../xdata/xodtemplate.c:8456
#2 0x080a1305 in xodtemplate_sort_serviceextinfo () at
../xdata/xodtemplate.c:9224
#3 0x080a0a32 in xodtemplate_sort_objects () at ../xdata/xodtemplate.c:8426
#4 0x080924ce in xodtemplate_read_config_data (main_config_file=0x8196a40
"admin_web,web,license", options=32511, cache=0) at
../xdata/xodtemplate.c:256
#5 0x0808ab87 in read_object_config_data (main_config_file=0x8191050
"/etc/nagios/nagios.cfg", options=32511, cache=0) at ../common/objects.c:97
#6 0x0806d870 in read_all_object_data (main_config_file=0x8191050
"/etc/nagios/nagios.cfg") at config.c:193
#7 0x0806870c in main (argc=0, argv=0xbffff794, env=0xbffff7a4) at
nagios.c:389
(gdb)
Thanks for looking into this.
Thomas
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf
> Of Ethan Galstad
> Sent: June 29, 2006 14:10
> To: Nagios-Devel
> Subject: Re: [Nagios-devel] Segfault during pre-flight check
> Hi Thomas -
> Can you try the following to generate a backtrace? This would be
> helpful in tracking down the problem...
> 1. Use the non-stripped nagios binary (located in the base/ subdir of
> the Nagios distro) for this procedure. If you're using an
> RPM install,
> get the source and compile it for yourself first.
> 2. From the command line...
> cd /base
> gdb nagios
> 3. From within gdb..
> 4. Once it segfault, gdb will stop and display an error message. Use
> the following command from within gdb to get a backtrace and
> see where
> they problem occurred...
> bt
> Send the output to (preferably) the list, or directly to
> myself if you'd
> like. Thanks!
> Thomas Guyot-Sionnest wrote:
> > Hi,
> > I'm maintaining a pretty big nagios setup (about 60 hosts/
> 600 services and
> > plan to grow that by 3-4 times). Most of the config is
> using templates to
> > save config lines and maintenance time. Every host has an
> extinfo (one
> > definition for each hostsgroup).
> > Now I started adding services extinfos to do some fancy
> things with e-mail
> > pages, and ran in a strange segfault bug. To explain it
> better I'll give an
> > overview of my config.
> > check
> [snip]
> > I'm sorry I didn't have time to cleanup all the config .
> I'm currently
> > setting another nagios box, so if I run into this problem
> at the very
> > beginning I'll keep that config and send it over. I also
> tried to get a core
> > dump but it didn't worked, I'm not sure if I need to enable
> some options at
> > compile time...
> > Thanks
> > Thomas
> Ethan Galstad,
> Nagios Developer
> Email: [email protected]
> Website: http://www.nagios.org
> Using Tomcat but need to do more? Need to support web
> services, security?
> Get stuff done quickly with pre-integrated technology to make
> your job easier
> Download IBM WebSphere Application Server v.1.0.1 based on
> Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk ... bid=263057&
> dat=121642
> Nagios-devel mailing list
> [email protected]
...[email truncated]...
