Re: [Nagios-devel] [Nagiosplug-devel] Idea to change nagios to
[email protected] schrieb:
> to all:
> This is more of a theorhetical question, but i am going to ask
> anyway.
> I believe that there would be a benefit to changing the standard plugin
> interface, and by default nrpe and associated programs to use xml as a
> communications standard.
> You would be able to intelligently send more differing types of data
> back from the plugin. The plugin would also be able to safely return
> html code (or xml code) that would allow you to offer more clickable
> information.
> Please let me know what you think of this idea. - keith
Hi Keith,
we already discussed on xml in performance data.
The problem is, that nagios prior to version 3 can only process
a couple of bytes (i guess it was sth < 512) of plugin output. So XML
would be to bloat for now.
Matthias
