Re: [Nagios-devel] Re: [netsaint-devel] 0.0.7 configure problems.
the output from the ping provided with redhat 7.3:
[root@arwen libexec]# ping -c 1 gugu.home
PING gugu.home (10.10.2.11) from 10.10.1.6 : 56(84) bytes of data.
64 bytes from gugu.home (10.10.2.11): icmp_seq=1 ttl=255 time=0.595 ms
--- gugu.home ping statistics ---
1 packets transmitted, 1 received, 0% loss, time 0ms
rtt min/avg/max/mdev = 0.595/0.595/0.595/0.000 ms
and here comes a redhat 7.2:
[root@cutter root]# ping -c 1 gugu.home
PING gugu.home (10.10.2.11) from 10.10.2.4 : 56(84) bytes of data.
64 bytes from gugu.home (10.10.2.11): icmp_seq=0 ttl=255 time=815 usec
1 packets transmitted, 1 packets received, 0% packet loss
round-trip min/avg/max/mdev = 0.815/0.815/0.815/0.000 ms
differences in the last two lines! when it hangs take a look at your
processlist:
[root@arwen libexec]# ps ax | grep ping
4394 pts/0 S 0:00 ping 127.0.0.1 -n 1
i encountered this problem when trying to compile netsaint-plugins. i
had to edit the configure scripts and the check_ping.c
nagios + nagios plugins compile just fine on rh7.3 btw.
bye,
markus
Subhendu Ghosh wrote:
> Ethan, others..
> On this issue with ping
> Should we look at only one of the two packages - nagios or the plugins
> providing check_ping. It does seem a bit redundant to patch both pieces
> every time.
> Since ping is a such a basic functionality should we just look at
> maintaining it with nagios ?
> -sg
> On Thu, 30 May 2002, Matthew Walburn wrote:
> > Hi there, I'm trying to get th new Netsaint working and am running into
> > problems getting the configure script to run right... it gets this far:
> > ./configure --prefix=/opt/netsaint --enable-embedded-perl --with-perlcache
> > checking for type of socket size... size_t
> > checking for mail... /bin/mail
> > Init script directory: /etc/rc.d/init.d
> > checking for gdImagePng in -lgd (order 1)... yes
> > GD library was found!
> > checking for traceroute... /usr/sbin/traceroute
> > checking for ping... /bin/ping
> > and the it just hangs there. I'm running Redhat 7.3 and near as I can
> > tell have all the required packages.
> > Any suggestions would be very helpful.
> > Thanks!
> > -Matt
> _______________________________________________________________
> Don't miss the 2002 Sprint PCS Application Developer's Conference
> August 25-28 in Las Vegas -- http://devcon.sprintpcs.com/adp/index.cfm
> Nagios-devel mailing list
> [email protected]
