--------------050709070907080604040000
Content-Type: text/plain; charset=ISO-8859-1
Async host check results get parsed differently from sync host and
service check results:
# grep -n parse_check_output nagios-3.2.3/*/*.c
nagios-3.2.3/base/checks.c
nagios-3.2.3/base/utils.c
escape_newlines_please, int newlines_are_escaped){
In 3.2.3, this causes the long output to be stored in the status.dat
with *actual* line breaks, while the same plugin output fed into a
service check has its line breaks changed to "\n":
# ../libexec/check_icmp_plus -H 127.0.0.1
OK - 127.0.0.1: rta 0,039ms, lost 0%|rta=3D0,039ms;200,000;500,000;0;
pl=3D0%;40;80;; rtmax=3D0,078ms;;;; rtmin=3D0,028ms;;;;
Long Output Zeile 1
Long Output Zeile 2
# grep 'Long Output' ../var/spool/status.dat
long_plugin_output=3DLong Output Zeile 1
Long Output Zeile 2
long_plugin_output=3DLong Output Zeile 1\nLong Output Zeile 2\n
extinfo.cgi, in turn, would read long_plugin_output=3D only up to the
first line break, thus missing the subsequent lines of the long output
entirely. (I'm also under the impression that restarting Nagios caused
the orphaned second line to simply *vanish* from status.dat until the
next check, but I didn't doublecheck.)
Note that in 3.2.2 and earlier, an independent bug in utils.c::2833
> http://nagios.cvs.sourceforge.net/viewv ... s.c?r1=3D=
1.249&r2=3D1.250
prevented the parameter value from actually taking effect.
Simply changing the parameters to (...,TRUE,TRUE) fixes this.
Kind regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
name="nagios-3.2.3-HostCheckParseFix-patch.txt"
filename="nagios-3.2.3-HostCheckParseFix-patch.txt"
--- nagios-3.2.3-CVS-20101105/base/checks.c 2010-10-28 19:39:35.000000000 +0200
+++ nagios-3.2.3+Fixes/base/checks.c 2010-12-03 19:45:33.000000000 +0100
@@ -3321,7 +3321,7 @@
my_free(temp_host->perf_data);
/* parse check output to get: (1) short output, (2) long output, (3) perf data */
- parse_check_output(queued_check_result->output,&temp_host->plugin_output,&temp_host->long_plugin_output,&temp_host->perf_data,FALSE,TRUE);
+ parse_check_output(queued_check_result->output,&temp_host->plugin_output,&temp_host->long_plugin_output,&temp_host->perf_data,TRUE,TRUE);
/* make sure we have some data */
if(temp_host->plugin_output==NULL || !strcmp(temp_host->plugin_output,"")){
--------------050709070907080604040000--
