Re: [Nagios-devel] nagios-cvs: reload/restart breaks
Hi John,
> # check to make sure nagios isn't stalled.
> */3 * * * * output=`/usr/lib/nagios/plugins/check_file_age -c 180
> /var/log/nagios` || /usr/bin/Mail -s "ALERT: Nagios stalled: $output"
> oncall_page_critical /dev/null
Why aren't you using check_nagios?
All my hosts/services are passive, so the scheduling queue is
useless...
> >To get it back working I have to remove all var/* files.
> I don't have to do that. Just stop and restart. So maybe you are
> seeing something new. Also what version are you running?
nagios-cvs - Nagios3
Gerd
