Your help in troubleshooting the following is really appreciated:
Configuration is as follows:
Nagios 2.0(02/07/2006) under Red Hat ES4(2.6.9-22.0.2.ELsmp).
Trying to reproduce the problem under Nagios 1.2(AIX 5.2) did not work, =
Nagios worked perfectly, the problem is only reproducible under 2.0, =
sorry, no testing has been done under 1.3.
To reproduce the problem(via Nagios web-interface):
choose any host via "Service Detail" with at least two services and do =
the following
select your first choice of service and scroll down to the link saying =
"Add a new comment" select this link and enter(i.e.) "#1" in the =
Comment-field, click commit
select your second choice of service(remember, on the same host), scroll =
down to the add-a-new-comment-link select that and enter(i.e.) "#2" in =
the Comment-field, click commit
check via "Service Detail" that both services got a comment-bubble(or =
your var/comments.dat)
now select your !second! choice of service again, scroll down and click =
on the "Delete all comments"-link, do NOT click on the "Delete this =
comment"-icon(the trash-icon) select Commit
check via "Service Detail" that the comment is deleted(no comment-bubble =
visible)
then select your !first! choice of service, scroll down and click on the =
check via "Service Detail" that the comment was NOT deleted.
I also did the above in a script(via ADD_SVC_COMMENT and =
DEL_ALL_SVC_COMMENTS), same problem. If I choose the trash-icon aside =
the comment and the comment-id is used for the deletion, that's working.
When doing a hexedit var/comments.dat the entry for service#2 looks =
fine, like the one for service#1. The entries in the Event Log also look =
the same, for both services. After restarting Nagios via "Process =
Info/Restart the Nagios process" a click on the "Delete all =
comments"-link works as expected, the comment is removed. I also tried =
./configure with --enable-DEBUGALL, but the only messages I'm getting =
are in the appache error log, saying "malformed header from script.", =
and apache isn't able to serve the http-pages...
But I think I'm getting closer to the problem.
This night five service checks(under the same host-entry) got processed =
like this:
The comments got entered in the following sequence(via ADD_SVC_COMMENT):
#1
#2
#3
#4
#5
Until now everything is working fine.
Now the service-checks ended in the following sequence and should have =
been removed via DEL_ALL_SVC_COMMENTS:
#2
#5
#4
#1
#3
But only the comments for service-checks
#2
#5
got removed(in this sequence).
The comments for
#4
#1
#3
are still in var/comments.dat and are not deletable, neither via =
DEL_ALL_SVC_COMMENTS nor the webinterface("Delete all comments").
Deleting them via the trashcan-icon(with the comment-id) works.
It looks like some kind of end-of-comment-list-pointer is moved in the =
list of comments:
Comment #2 gets deleted, the pointer in the list of comments gets moved =
to entry #2
Comment #5 gets deleted, the pointer in the list of comments gets moved =
to entry #5, which is the last in the list
Now comment #4 should get deleted, but does not, because the =
end-of-comment-list-pointer is further down the list, so the comment =
can't get deleted.
Same with comment #1 and #3, both are above the =
end-of-comment-list-pointer.
If somebody could confirm the above, please, to make sure it's not my =
local mistake?
Thank you for your time,
J=F6rg Berning
