Re: [Nagios-devel] Strange characters in output when
Hendrik Bäcker wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi List,
> I've played a little bit with the actual cvs code and I can say:
> 1. Yes - it's a bug ;)
> 2. No - I don't have a patch
> 3. Yes - I think I've found the killer
> 4. No - I don't know what there's going on - but perhaps others can
> explain.
> My testing environment:
> 1. Edit the /bin/p1.pl on line
> after line 294:
> untie *STDOUT;
> add:
> print "PRIVATE DEBUG p1.pl says: $plugin_output\n";
> or trust me when I say: in p1.pl the output is fine!
> 2. change base/checks.c around line 639 so that we have:
> perl_plugin_output=POPpx;
> printf("PRIVATE DEBUG: Nagios says after POPpx: %s\n",perl_plugin_output);
> // Trust me Output is fine
> pclose_result=POPi;
> printf("PRIVATE DEBUG: Nagios says after POPi: %s\n",perl_plugin_output);
> PUTBACK;
> printf("PRIVATE DEBUG: Nagios says after PUTBACK: %s\n",perl_plugin_output);
> FREETMPS;
> printf("PRIVATE DEBUG: Nagios says after FREETMPS:
> LEAVE;
> printf("PRIVATE DEBUG: Nagios says LEAVE: %s\n",perl_plugin_output);
> My Output after compile and force a ePN Plugin Check:
> PRIVATE DEBUG: p1.pl says: CRITICAL - Test down
> PRIVATE DEBUG: Nagios says after POPpx: CRITICAL - Test down
> PRIVATE DEBUG: Nagios says after POPi: CRITICAL - Test down
> PRIVATE DEBUG: Nagios says after PUTBACK: CRITICAL - Test down
> So.. there seem to be a problem with FREETMPS...
> On http://perldoc.perl.org/perlcall.html there is the info:
> The FREETMPS /LEAVE pair will get rid of any values returned by the
> Perl subroutine (see next example), plus it will also dump the mortal
> SVs we have created. Having ENTER /SAVETMPS at the beginning of the
> code makes sure that no other mortals are destroyed.
> I can imagine that the FREETMPS is destroying to much of the stack where
> the var plugin_output lives... but this is only a thought.
> Are there any Perl / C gurus out there who can explain this behavior?
> Regards
> Hendrik
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> iD8DBQFGlmy/lI0PwfxLQjkRAj+oAJ9YNCXFoDI9/2fpxs8bFGWsA+3v2ACfRhVy
> DKqMrGX6BMrkgyOj4RBBMac=
> =Uyyt
> -----END PGP SIGNATURE-----
Good debugging! It looks as though the POPpx pointer was invalid after
the FREETMPS call. I compared the Nagios 3.x code to 2.x and found that
I moved the code that save the plugin output to a point after the
FREETMPS call. I just fixed the code (and verified it works). Patch
has been posted to CVS. :-)
Ethan Galstad,
Nagios Developer
Email: [email protected]
