Re: [Nagios-devel] host check strangeness - odd behavior in Nagios
>> Problem 1. Some host checks are getting *stuck* in scheduling queue.
>> When I look at the scheduling queue these hosts are always listed
with=20
>> the 'last check' time the same as it's 'next check' time. See=20
>> attached screen shot (problem 1). They typically stay at the top of=20
>> the queue for an hour or two.
>>=20
>Does this problem persist if you specify active_checks_enabled
specifically in the host object definition itself?
No that did not make any difference.
>>=20
>> Problem 2. Many of our hosts are not running host checks, they are
in=20
>> the scheduling queue but don't execute. Looking at the scheduling=20
>> queue I can see many of the hosts that have host 'last check' times=20
>> from several weeks ago. They show up in the queue but never run
their=20
>> host checks (or don't seem to). These same hosts run service checks=20
>> on time without issue. Screen shot attached (problem 2).
>>=20
No difference here either.
-greg
