Re: [Nagios-devel] [patch] Parent checking fails with
On 04/26/2011 03:52 PM, Andrew Norris wrote:
> In nagios 3.2.3 parent checks are not properly handled when
> max_check_attempts is set to 1. run_sync_host_check_3x properly
> executes the host check if not using cached data, but it never sets
> check_result_code. This one-liner fixes that.
> I didn't delve too deep, but I think the patch is correct. We have had
> this running in production for a couple weeks now and it's saved us from
> a deluge of notifications.
I think you forgot to attach (or inline) the patch.
OP5 AB www.op5.se
on peace.
