[Nagios-devel] Patch against bug in processing passive checks with
--------------010209000004020003030301
Content-Type: text/plain; charset=ISO-8859-15
Hi List,
hi Ethan,
I know, brand hot but there is an bug while writing passive check
results to the temp spool file.
temp_pcr->service_description is always (null).
I think moving one parenthese will solve the problem. Tests looks good now.
Patch against latest cvs code:
Content-Type: text/x-patch;
name="commands.c.patch"
Content-Disposition: inline;
filename="commands.c.patch"
--- nagios3-clean/base/commands.c 2007-04-18 10:29:33.000000000 +0200
+++ nagios3/base/commands.c 2007-04-18 11:06:09.000000000 +0200
@@ -5349,7 +5349,7 @@
fprintf(checkresult_file_fp,"# Time: %s",ctime(&temp_pcr->check_time));
fprintf(checkresult_file_fp,"host_name=%s\n",(temp_pcr->host_name==NULL)?"":temp_pcr->host_name);
if(temp_pcr->object_check_type==SERVICE_CHECK)
- fprintf(checkresult_file_fp,"service_description=%s\n",(temp_pcr->service_description)==NULL)?"":temp_pcr->service_description;
+ fprintf(checkresult_file_fp,"service_description=%s\n",(temp_pcr->service_description)==NULL?"":temp_pcr->service_description);
fprintf(checkresult_file_fp,"check_type=%d\n",(temp_pcr->object_check_type==HOST_CHECK)?HOST_CHECK_PASSIVE:SERVICE_CHECK_PASSIVE);
fprintf(checkresult_file_fp,"scheduled_check=0\n");
fprintf(checkresult_file_fp,"reschedule_check=0\n");
--------------010209000004020003030301--
