[Nagios-devel] Patch - incorrect default for aggressive_host_checking
The analysis below is correct. We should either update the documentation
and configuration files to reflect this, or apply the following patch:
*** base/nagios.h.in_orig Fri Aug 27 14:47:54 2004
--- base/nagios.h.in Fri Aug 27 14:48:02 2004
*** 80,86 ****
#define DEFAULT_LOG_EXTERNAL_COMMANDS 1 /* log external commands */
#define DEFAULT_LOG_PASSIVE_CHECKS 1 /* log passive service checks */
! #define DEFAULT_AGGRESSIVE_HOST_CHECKING 1 /* use "aggressive" host checking */
#define DEFAULT_CHECK_EXTERNAL_COMMANDS 0 /* don't check for external commands */
#define DEFAULT_CHECK_ORPHANED_SERVICES 0 /* don't check for orphaned services */
#define DEFAULT_ENABLE_FLAP_DETECTION 0 /* don't enable flap detection */
--- 80,86 ----
! #define DEFAULT_AGGRESSIVE_HOST_CHECKING 0 /* use "aggressive" host checking */
On Thu, Aug 26, 2004 at 06:31:33PM -0700, Quanah Gibson-Mount wrote:
> After pulling down the default configs, and comparing my nagios.cfg with
> its nagios.cfg, I started adding in various things that weren't in the
> nagios.cfg we deploy because the documentation states they have default
> values.
> At some point, host down alerts started working as expected, so I backed
> out the changes until they stopped working again.
> This occurred at the point at which I removed the
> "use_aggressive_host_checking=0" line (My email client will not let me
> spell it the incorrect way it is spelled in Nagios :P ).
> According to the Nagios documentation, this parameter is supposed to be
> defaulted to 0:
> (Damn, even the link is wrong because my email client is throwing in the
> extra g to make it spelled correctly).
> So there is a bug in that logic somewhere.
> obsess_over_services
> does not exhibit similar behavior with services, since I didn't have that
> defined either, and service alerts were never an issue.
> --Quanah
> Quanah Gibson-Mount
> Principal Software Developer
> ITSS/Shared Services
> Stanford University
> GnuPG Public Key: http://www.stanford.edu/~quanah/pgp.html
> SF.Net email is sponsored by Shop4tech.com-Lowest price on Blank Media
> 100pk Sonic DVD-R 4x for only $29 -100pk Sonic DVD+R for only $33
> Save 50% off Retail on Ink & Toner - Free Shipping and Free Gift.
> http://www.shop4tech.com/z/Inkjet_Cartridges/9_108_r285
> Nagios-users mailing list
> [email protected]
> https://lists.sourceforge.net/lists/lis ... gios-users
> ::: Please include Nagios version, plugin version (-v) and OS when
> reporting any issue. ::: Messages without supporting info will risk being
> sent to /dev/null
Joe Rhett
Senior Geek
Meer.net
