> Mathieu Gagné wrote:
>> On 6/5/09 6:29 PM, Steven D. Morrey wrote:
>>> p.s. Let me know how that patch goes on a 3x system I don't have a
>>> running 3x to test it on, so all i can promise with that one is that it compiles
>> I'm trying it on a Nagios 3.0.6 system. Note that I had to remove all
>> references to EVENT_CHECK_PROGRAM_UPDATE because it's an event only
>> available in Nagios 3.1.x.
>> All volatile data are already located on tmpfs partitions. So I'll have
>> to try without tmpfs partitions afterward so I can compare impact on
>> performances.
> Steve, thanks for the patch. Mathieu, thanks for testing it out. If it's
> useful to you, I'll apply it and make sure it's included in 3.1.1. The
> data we might be able to gather from it may well be important for the
> 3.2.0 release.
what would be the impact of having this feature be a configuration
setting in nagios.cfg, instead of having to compile with a flag to get
the behavior? I'm wondering if it would be useful to be able to switch
it on to get some information (perhaps during diagnosing something) and
switch it off again if it's not wanted, without needing to recompile
nagios for this?
