------=_NextPart_000_000D_01C1A109.DEC059D0
Content-Type: text/plain;
charset="iso-8859-1"
Nagios 1.0a2 does not process definitions contained in text files under the
normal default object definition method (--with-default-objects). The
following attached patch fixes this problem.
Randy
Content-Type: application/octet-stream;
name="xoddefault.c.patch"
filename="xoddefault.c.patch"
Index: xdata/xoddefault.c=0A=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=0A=
RCS file: /liblin/cvsrepo1/nagios/xdata/xoddefault.c,v=0A=
retrieving revision 1.1.1.2=0A=
diff -u -r1.1.1.2 xoddefault.c=0A=
--- xdata/xoddefault.c 2002/01/18 04:50:25 1.1.1.2=0A=
+++ xdata/xoddefault.c 2002/01/20 00:35:34=0A=
@@ -92,7 +92,7 @@=0A=
if(strstr(temp_ptr,"xoddefault_config_file")=3D=3Dtemp_ptr || =
strstr(temp_ptr,"cfg_file")=3D=3Dtemp_ptr){=0A=
=0A=
/* get the config file name */=0A=
- temp_ptr=3Dstrtok(NULL,"\n");=0A=
+ temp_ptr=3Dmy_strtok(NULL,"\n");=0A=
if(temp_ptr=3D=3DNULL)=0A=
continue;=0A=
=0A=
------=_NextPart_000_000D_01C1A109.DEC059D0--
