Re: [Nagios-devel] question regarding nagios.cmd
enediel gonzalez wrote:
> Thanks a lot for your answer
> I found a set of entries on nagios.log like the following ones
> [1128627994] service_result_worker_thread(): poll(): EINTR (impossible)
> [1128633624] service_result_worker_thread(): poll(): EINTR (impossible)
> How I should interact with nagios in a safe way to avoid this kind of
> problem, I need to put some processes on debian that will configure
> automatically the shedule downtimes.
> If the answer is well explained somewhere, please just send me the
> references to find it.
It isn't. I wrote that error-detection code, but there's no handling for
any of the errors it detects. It was originally done as debug-code that
made it into main because it *could* happen but was never expected to.
In this particular case, EINTR should never happen (as it says), since
the sigprocmask() called earlier in the command-reaper thread is
supposed to ignore all signals (the main thread handles signals).
SIGKILL can ofcourse still happen, but it wouldn't log anything for that.
OP5 AB www.op5.se
