--nextPart1563868.SlhgDr7ZVi
Content-Type: text/plain;
charset="iso-8859-1"
Content-Disposition: inline
=2D--------- Forwarded Message ----------
Subject: Re: [Nagios-devel] the new gui?
Date: Tuesday 17 January 2006 23:07
=46rom: Eldad Zack
To: [email protected]
On Tuesday 17 January 2006 20:57, Hendrik Baecker wrote:
> The next step for multi language Support and perhaps some template based
> gui could be another php class called smarty (http://smarty.php.net/).
> They did a good cut between colored frontend and the main application.
> In the end of development using Smarty there are the developers giving
> some smarty internal variables out of, hopefully, nice functions
> (selects and so on) and there are the Web Designer "just" making a
> wonderful GUI feeded with the dynamically smarty Variables.
=46rom my own exprience with smarty it makes you punch out much clearer and
cleaner code. I've used it in my half-baked nagios v1 php interface
(nagios-php.sf.net) quite extensively.
=46or reference:
http://sourceforge.net/projects/nagios-php/
I would vote highly for using it in the future implementation of the nagios
php interface.
I assume that the event broker will make it much easier than needing to par=
se
files.
Also, as a part of the command implentation I've made an XML detailing the
external commands to be used:
http://cvs.sourceforge.net/viewcvs.py/n ... ml/cmd.de=
f.
xml?rev=3D1.15&view=3Dauto
Maybe this could be brought closer to the nagios core in the next cycle?
If it will be shared between the core and the Web UI, it'll make life easier
on the development, and less code replication...
=2D-
Eldad Zack
Key/Fingerprint at pgp.mit.edu, ID 0x96EA0A93
=2D------------------------------------------------------
Content-Type: application/pgp-signature
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2-ecc0.1.6 (GNU/Linux)
iD8DBQBDzV3mT+MN7JbqCpMRAqk1AJ9wW3LIq7uai3RZCBAgbJY911Qe0wCeKQ+G
mxBr8qW85XxMV5CQh0kBDm8=
=Qa0h
-----END PGP SIGNATURE-----
--nextPart1563868.SlhgDr7ZVi--
