[Nagios-devel] Inherited custom object vars using definitions in
Hi,=20
We would like to utilize resource.cfg for holding secrets, and we are
trying to do something like this:
Passwords in resource.cfg:
$USER20$=3Dsecret1
$USER21$=3Dsecret2
Each host use one of the passwords in hosts.cfg:
define host {
use generic-host
host_name host1
alias host1
address ip1
_snmp_community $USER20$
Services use the community in services.cfg:
host_name host1
service_description snmp_check_load
check_command check_snmp_11187
command_name check_snmp_11187
command_line $USER1$/check_snmp -H $HOSTADDRESS$ -C
$_HOSTSNMP_COMMUNITY$ -o .1.3.6.1.... -w 70=20
But $_HOSTSNMP_COMMUNITY$ appears to be not set once it reaches the
command_line?
Using something like this (defining the password directly in hosts.cfg,
without going through resource.cfg):
_snmp_community secret3
Appears to work ok - so what is hindering the other approach? Is there
an undocumented expansion order preventing the hierarchical use? And,
more importantly - is this per spec or in error? :-)
Best regards,
Steffen Poulsen
