------_=_NextPart_001_01C72499.7F843DA0
Content-Type: text/plain;
charset="iso-8859-1"
Ndoutils 1.3.1 does not want to build properly on Linux/x86_64, at least =
not on my Sun x4200 AMD64 based system. It looks like io.c and utils.c =
are not being compiled with -fPIC despite being linked into the =
ndomod-?x.o module. Looks like the linkage uses -fPIC, but not the =
compilation of those two source files.
I've attached a patch that basically just adds $(MOD_CFLAGS) for those =
two files. This solves the problem for me since MOD_CFLAGS contains =
-fPIC, at least for linux*. Some tweaks to configure.in may be needed to =
fix other platforms, if this is a problem for other 64-bit platforms.
Ryan
Ryan Ordway=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 Unix Systems =
Administrator
OSU Libraries=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 E-mail: =
[email protected]
121 The Valley Library=A0=A0=A0=20
Corvallis, OR 97331=A0=A0=A0=A0=A0=A0 Office: VLIB #4657
Content-Type: application/octet-stream;
name="ndoutils-Makefile-fPIC.patch"
Content-Description: ndoutils-Makefile-fPIC.patch
filename="ndoutils-Makefile-fPIC.patch"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------_=_NextPart_001_01C72499.7F843DA0--
