Re: [Nagios-devel] nagios 3.0b3 ochp problem
Activating the debug option gives me the following output
[1190886551.165209] [016.2] [pid=3D22578] Parsing check output...
[1190886551.165224] [016.2] [pid=3D22578] Short Output: CRITICAL -
10.176.77.85: Host unreachable @ 10.176.77.57. rta nan, lost 100%
[1190886551.165237] [016.2] [pid=3D22578] Long Output: NULL
[1190886551.165249] [016.2] [pid=3D22578] Perf Data: =20
rta=3D0.000ms;3000.000;5000.000;0; pl=3D100%;80;100;;
[1190886551.165261] [001.0] [pid=3D22578] process_host_check_result_3x()
[1190886551.165273] [016.1] [pid=3D22578] HOST: U3RIPC85, ATTEMPT=3D1/10, =
CHECK
TYPE=3DACTIVE, STATE TYPE=3DHARD, OLD STATE=3D1, NEW STATE=3D1
[1190886551.165291] [016.1] [pid=3D22578] Host was DOWN/UNREACHABLE.
[1190886551.165303] [016.1] [pid=3D22578] Host is still DOWN/UNREACHABLE.
[1190886551.165315] [001.0] [pid=3D22578] determine_host_reachability()
[1190886551.165327] [016.2] [pid=3D22578] Determining state of host
'U3RIPC85': current state=3D1
[1190886551.165340] [016.2] [pid=3D22578] At least one parent (HPSWITCH) =
is
up, so host is DOWN.
[1190886551.165353] [016.1] [pid=3D22578] Pre-handle_host_state() Host:
U3RIPC85, Attempt=3D1/10, Type=3DHARD, Final State=3D1
[1190886551.165366] [001.0] [pid=3D22578] handle_host_state()
[1190886551.165400] [001.0] [pid=3D22578]
obsessive_compulsive_host_check_processor()
[1190886551.165480] [001.0] [pid=3D22578] process_macros()
[1190886551.165495] [2048.1] [pid=3D22578] **** BEGIN MACRO PROCESSING
[1190886551.165508] [2048.1] [pid=3D22578] Processing:
'http://10.176.77.57/nagios/cgi-bin/exti ... HOSTNAME$=
[1190886551.165521] [2048.2] [pid=3D22578] Processing part:
'http://10.176.77.57/nagios/cgi-bin/exti ... D1&host=3D'
[1190886551.165535] [2048.2] [pid=3D22578] Not currently in macro. =
Running
output (59): =
[1190886551.165547] [2048.2] [pid=3D22578] Processing part: 'HOSTNAME'
[1190886551.165580] [2048.2] [pid=3D22578] Uncleaned macro. Running =
output
(67): =
'http://10.176.77.57/nagios/cgi-bin/exti ... 3DU3RIPC85'
[1190886551.165595] [2048.2] [pid=3D22578] Just finished macro. Running
output (67):
[1190886551.165608] [2048.1] [pid=3D22578] Done. Final output:
[1190886551.165620] [2048.1] [pid=3D22578] **** END MACRO PROCESSING
[1190886551.165686] [001.0] [pid=3D22578] get_raw_command_line()
[1190886551.165701] [2320.2] [pid=3D22578] Input: =
$USER2$/submit_check_result
$HOSTNAME$ $HOSTSTATEID$ '$HOSTOUTPUT$'
[1190886551.165714] [2320.2] [pid=3D22578] Output:
$USER2$/submit_check_result $HOSTNAME$ $HOSTSTATEID$ '$HOSTOUTPUT$'
[1190886551.165727] [016.2] [pid=3D22578] Raw obsessive compulsive host
processor command line: $USER2$/submit_check_result $HOSTNAME$
[1190886551.165739] [001.0] [pid=3D22578] process_macros()
[1190886551.165751] [2048.1] [pid=3D22578] **** BEGIN MACRO PROCESSING
[1190886551.165763] [2048.1] [pid=3D22578] Processing:
'$USER2$/submit_check_result $HOSTNAME$ $HOSTSTATEID$ '$HOSTOUTPUT$''
[1190886551.165776] [2048.2] [pid=3D22578] Processing part: ''
[1190886551.165789] [2048.2] [pid=3D22578] Not currently in macro. =
Running
output (0): ''
[1190886551.165801] [2048.2] [pid=3D22578] Processing part: 'USER2'
[1190886551.165818] [2048.2] [pid=3D22578] Cleaned macro. Running =
output
(39): '/usr/local/nagios/libexec/eventhandlers'
[1190886551.165850] [2048.2] [pid=3D22578] Just finished macro. Running
output (39): '/usr/local/nagios/libexec/eventhandlers'
[1190886551.165864] [2048.2] [pid=3D22578] Processing part:
'/submit_check_result '
[1190886551.165877] [2048.2] [pid=3D22578] Not currently in macro. =
Running
output (60): '/usr/local/nagios/libexec/eventhandlers/submit_check_result =
[1190886551.165890] [2048.2] [pid=3D22578] Processing part: 'HOSTNAME'
[1190886551.165904] [2048.2] [pid=3D22
...[email truncated]...
