Re: [Nagios-devel] NDO update delay
Hash: SHA1
Rodney Ramos schrieb:
> Hi, Hendrik. Thanks for your answer.
> =20
>> Guess what - your nagios isn't monitoring anything in that time... ;(
> =20
> I didn=B4t understand. I can see the "last check" date updated correctl=
y
> on Nagios Web Interface each 5 minutes. On the other hand, the field on
> the MySQL is update, but with a 30 minutes of delay, or more.
> =20
I'm sorry - I thought of the wrong blocking thing.
Sorry for the confusion.
Need more information on this.
Nagios and DB on the same host?
Host stressed up?
>> Did you set all those indizies from "db/mysql-mods-1.4b7.sql" ?
> =20
> I=B4ve created NDO tables as told in the manual, running "db/installdb"
> script.
>=20
I would suggest to first backup or mirror your database, apply the
mysql-mods-VERSION.sql file, it should set up some finer indizies, test
your app and decide to fall back to your old scheme or keep the new one
(with more indizies).
Think about the three magic words in IT: BACKUP, BACKUP, BACKUP
on the other side: Never touch a running system, neverever on friday ;)
Regards,
Hendrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAknNP5cACgkQlI0PwfxLQjn3eACZAQsHkKiPEylrSLZFCBqO9Gho
3GQAnjaHQy+ok9gAhFIM6Imy8cDhqv4K
=3DZp1l
-----END PGP SIGNATURE-----
