[Nagios-devel] Potential Bug
I just ran into this one in 1.0b6 using the nagios -v check:
If you have an entry in the members section of a hostgroup definition
that isn't the name of a host, instead of giving an error about an
unknown host, you only get a warning. And the warning you get isn't
about an unknown host, but instead a warning that several hosts are not
part of a hostgroup. The hosts listed in the warning are all the ones
that come after the undefined host.
Example:
define hostgroup{
members host1,host2,host3,hostX,host5,host6,host7
contact_groups ops
alias Internal Hosts
hostgroup_name internal_hosts
If hostX isn't defined in the configs, when you run nagios -v, you get
the message
Warning: Host 'host5' is not a member of any host groups!
Warning: Host 'host6' is not a member of any host groups!
Warning: Host 'host7' is not a member of any host groups!
instead of an error that hostX doesn't exist.
-Russell
Russell Scibetti
Quadrix Solutions, Inc.
http://www.quadrix.com
(732) 235-2335, ext. 7038
