hi bill.
you need to much around with the makefile and move -lmysqlclient to
the end i thinjk
----- Original Message -----
Date: Fri, 10 Sep 2004 14:36:52 -0600
Subject: [Nagios-devel] Problem compiling Nagios with mysql support on Solaris 9
To: [email protected]
All,
I am trying to compile Nagios 1.2 with mysql support on a Solaris 9
box and keep getting the following error:
ld: fatal: Symbol referencing errors. No output written to nagios
collect2: ld returned 1 exit status
Nagios compiles fine if I don't use mysql.
I am using the following to configure Nagios:
./configure --with-mysql-xdata
--with-mysql-inc=/usr/local/mysql/include
--with-mysql-lib=/usr/local/mysql/lib
No errors on the configure, just when I make.
Any suggestions on what I need to do to resolve this issue? I'm using
mysql V 4.0.21. I included the complete make output below.
Thanks.
Bill
Bill Winkles
Lucent Technologies
m
Sr. Technical Engineer
Global Network Operations Center - Denver
( +1 720/482-6528 (Voice)
( +1 303/941-2455 (Mobile)
# make all
cd ./base && make
make[1]: Entering directory `/billy/nagios/nagios-1.2/base'
gcc -g -O2 -I/usr/local/mysql/include -DHAVE_CONFIG_H -DNSCORE
-L/usr/local/mysq
l/lib -lmysqlclient nagios.c checks.o config.o commands.o flapping.o logging.o
notifications.o sehandlers.o utils.o sretention.o ../xdata/xrddb.c
../common/com
ments.c ../xdata/xcddb.c ../common/objects.c ../xdata/xodtemplate.c
../common/st
atusdata.c ../xdata/xsddb.c perfdata.o ../xdata/xpddefault.c
../common/downtime.
c ../xdata/xdddb.c -lm -o nagios
Undefined first referenced
symbol in file
mysql_fetch_row /var/tmp//cceGv5Hq.o
mysql_query /var/tmp//cceGv5Hq.o
mysql_errno /var/tmp//ccDJD4XD.o
mysql_close /var/tmp//cceGv5Hq.o
mysql_insert_id /var/tmp//ccQzsQ08.o
mysql_free_result /var/tmp//cceGv5Hq.o
mysql_store_result /var/tmp//cceGv5Hq.o
mysql_init /var/tmp//cceGv5Hq.o
mysql_real_connect /var/tmp//cceGv5Hq.o
make[1]: *** [nagios] Error 1
make[1]: Leaving directory `/billy/nagios/nagios-1.2/base'
make: *** [all] Error 2
