Hi Ingo,
Hi all,
at least Im sure there is a problem with the epn concering Plugin-Output.
I remarked this already some month ago for 3.0a1 and looking for other
guys,
seeing the same problem. ([Nagios-devel] problems epn with 3.0a1 ,
21.03.2007)
In between there have been some more discussion concerning epn that the
plugin result
is scrambled up Inside the empedded Perl, the plugin putput is correct,
but when the output reaches
nagios, the first 4 or 8 byte of Plugin Output seems to be overwritten.
I do not understand embedded perl in detail, but perheaps there is
someone else, who can
have a look at that problem.
I think it's a real problem for nagios 3.0, because a lot of people use
epn due to perfomance.
All those guys cannot switch over to nagios 3.0 without epn.
Regards
Ingo Lantschner schrieb:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> using check_logfiles to search for Portscans in /var/log/snort/alert
> I get this output:
> &#-56;&#-99;h&#-22;> - (3 errors in
> check_logfiles.protocol-2007-07-06-11-08-53) - [**] [122:1:0]
> (portscan) TCP Portscan [**] ...
> The wired characters starting with & and ending with > should read
> CRITICAL. Similar garbage is returned with OK, just shorter.
> The characters *change* with each (re)check and they are NOT shown if
> check_logfiles is called from the command-line.
> I already contacted the author of the plugin, he never has seen this
> before - so I guess there is a relation to the Nagios release 3.x
> Other plugins (check_load, check_users, etc. from 1.4.9) do NOT show
> this behavior.
> Looking into nagios.log I find lines related to check_logfiles with
> "Additional Info: \n\nI" and similar.
> Nagios 3.0a5 on Ubuntu Server 6.01 with Apache 2.0.55 and
> check_logfiles v2.2.4.1.
> Any idea?
> Cheers, Ingo
> Ingo Lantschner
> Vienna/Austria
> Mob (+43-664) 143 84 18
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.7 (Darwin)
> iD8DBQFGk5W9encxbxkaIHoRAkT9AJ0flIFfK+srTv6jb4HkBAMEDQJQ9wCeOJJX
> SLJ9GEbYilouL98e/EpYA5U=
> =mqOM
> -----END PGP SIGNATURE-----
> This SF.net email is sponsored by DB2 Express
> Download DB2 Express C - the FREE version of DB2 express and take
> control of your XML. No limits. Just data. Click to get it now.
> http://sourceforge.net/powerbar/db2/
> Nagios-devel mailing list
> [email protected]
