Re: [Nagios-devel] Nagios retries checks too soon.
Jochen Bern wrote:
> On 06/09/2011 08:14 PM, Paul M. Dubuc wrote:
>> Andreas Ericsson wrote:
>>> I'm not sure. I'm also not sure which behaviour is intended. Arguably, either
>>> is correct and Nagios is doing one of two right things.
>> I'm not sure. If a test times out and Nagios tries again 10 seconds later
>> instead of the 60 seconds specified, that could cause problems; load related
>> problems when you have many of these tests running and timing out and problems
>> for the system under test not having sufficient time to recover before the
>> next check is done.
> True, but *if* someone has the latter kind of problem, I'd expect him to
> keep it in mind while writing the configuration, too. IIRC, the actual
> code adds check_interval/retry_interval to the variable that holds the
> (previous) scheduled check time - i.e., the time when the previous check
> supposedly was *started* (assuming negligible check latency).
> Configuring a retry_interval of one minute for a service whose sustained
> request rate may be *less* than one per minute sounds dubitable to me.
> (And I'm a firm nonbeliever in Unix-ish "load" figures, as opposed to
> actual CPU usage etc., but that's a different rant.)
> Kind regards,
> J. Bern
Thanks for this explanation. It helps quite a bit. The checks we run
normally take 5 - 15 seconds to complete, but we allow a much longer
value for timeout. I was under the impression that the retry interval
was only counted from the time the previous check completes and the
status (which is needed to determine if a retry is necessary) is known.
Why is the retry time determined before it's know that one is needed?
It looks like checks that have longer timeouts need to have longer
retry intervals to compensate for the worst case. That's not intuitive
to me, but I can live with it.
Paul Dubuc
