Re: [Nagios-devel] NRPE - performance data larger than 1024B
No, you can update first check_nrpe on your main nagios machine and lat=
ter update all NRPE agent. The check_nrpe plugin is backward compatible=
with non-patched NRPE agent.
Of course, if you wan't large output, you need to update both check_nrp=
e and NRPE agents. But with this patch, you can update only required ag=
ent that need large output.
For your information, I'm using this patch since 2 years on about 500 m=
achines (AIX, Solaris and Linux) with about 6500 services.
Regards,
Yannig
Le mardi 27 mars 2012 23:44:52 Andreas Ericsson a =C3=A9crit :
> On 03/26/2012 11:40 AM, Ryszard =C5=81ach wrote:
> > Hi.
> >=20
> > Someone replied to my post on nagios forum, that devel list would b=
e
> > better for my topic, so I'm repeating my question here.
> >=20
> > I'm considering to integrate my Nagios server with Nagiosgraph (and=
> > possibly migrate with performance graphs from Munin). Unfortunately=
> > some graphs cannot work correctly because of max packet size (e.g.
> > check_disk for some of my servers).
> >=20
> > There is a working patch, see
> > http://labs.opsview.com/2008/08/enhanci ... ge-output/ - =
it
> > looks nice and works perfect - I've checked patched nrpe_check (2.1=
2)
> > with unpatched/patched nagios-nrpe-server.
> >=20
> > Is it possible, that some day you include such a patch in nagios up=
stream?
> >=20
>=20
> Yes.
>=20
> I'm not NRPE maintainer though, but I'm looking into that very patch
> right now. It does require updating both client and agent though.
>=20
