Re: [Nagios-devel] alternative scheduler
Andreas,
You are running 150k active checks per 5 minutes on a virtual
machine?! Wow! I remember you echoing in the not too distant past
what many of us have experienced - that timing skew and I/O
performance on virtual machines make them bad candidates for Nagios -
what kind of VM set up are you using that has changed your mind?
Are your checks all c-based?
Max
On 11/24/10, Andreas Ericsson wrote:
> On 11/23/2010 01:59 PM, Fredrik Thulin wrote:
>> In case that was too long for y'all, the short story is that I got lousy
>> performance from the service check scheduler in Nagios (3.2.0, sorry -
>> forgot to mention that).
>> I was able to write a brand new scheduler that works MUCH better - 1160
>> checks per minute, compared to ~60. Any plans to do something drastic
>> about the Nagios service check scheduler?
> I have no idea what you did to Nagios to make it run only 60 checks per
> minute. With a distributed setup, using 5 virtual machines and Merlin to
> connect them, I've managed to schedule, run and reap roughly 750k checks
> per 5 minutes. Clearly, you're doing something amazingly weird in your
> configuration. Have you set parallelize_check to 0 in some template
> somewhere, or turned it off globally in nagios.cfg? Are you using an
> OCS[PH] command that takes forever to run, or is your perfdata handling
> completely bonkers? 60 checks per minute is nothing, and if that was the
> limit of what Nagios can manage to execute, nobody would use it.
> Andreas Ericsson [email protected]
> OP5 AB www.op5.se
> Tel: +46 8-230225 Fax: +46 8-230231
> Considering the successes of the wars on alcohol, poverty, drugs and
> terror, I think we should give some serious thought to declaring war
> on peace.
> Increase Visibility of Your 3D Game App & Earn a Chance To Win $500!
> Tap into the largest installed PC base & get more eyes on your game by
> optimizing for Intel(R) Graphics Technology. Get started today with the
> Intel(R) Software Partner Program. Five $500 cash prizes are up for grabs.
> http://p.sf.net/sfu/intelisp-dev2dev
> Nagios-devel mailing list
> [email protected]
