Re: [Nagios-devel] Event Handler Arguments?
Command arguments for event handlers, notifications, host checks, and
other commands have already been implemented in the 2.x code. :-)
On 4 Jun 2003 at 17:34, Russell Scibetti wrote:
> I have a possibly useful feature request for Nagios. Currently, in a
> service definition, the check_command line takes the name of a defined
> command, and then arguments (separated by "!"). These can then be
> references in the command as $ARG#$.
> Now, the event_handler line also takes the name of a defined command,
> but there is no ability to pass arguments. If the functionality
> already exists to pass arguments to a check_command, I can't see it
> being very difficult to implement for event_handlers as well. Take,
> for example, a service that has a specific port pass to the
> check_command as an argument. If you want to restart this service,
> you might need that port number again in the event handler.
> So what do people think? Ethan, would this be difficult to add for
> 2.0?
> Russell Scibetti
> Quadrix Solutions
> Russell Scibetti
> Quadrix Solutions, Inc.
> http://www.quadrix.com
> (732) 235-2335, ext. 7038
> This SF.net email is sponsored by: Etnus, makers of TotalView, The
> best thread debugger on the planet. Designed with thread debugging
> features you've never dreamed of, try TotalView 6 free at
> www.etnus.com. _______________________________________________
> Nagios-devel mailing list [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
