Hello.
I came across a *very* weird problem which seems to be more of a code
issue than a usage issue (although I could be wrong). My initial
hosts and servcies files had options set for each element. For
example,
# 'novell1' host definition
use generic-host ; Name of
host template to use
host_name novell1
alias Novell Server #1
address 192.168.1.2
max_check_attempts 10
notification_interval 120
notification_period 24x7
notification_options d,u,r
register 0
Each host had an entry like the one above. But then I read the
section on templates in the manual, and thought it would be easier to
have things like check_command, max_check_attempts, etc placed into a
template and have host definitions have only the name, alias and
address for each. The rest would come from the template.
But when I did that, the logs DISAPPEARED at log rotation time.
nagios.log is wiped for the new day's logs, but the archives file for
the day that just passed is empty. Since this is a critical matter,
any help as soon as possible would be GREATLY appreciated.
I am still receiving email notifications when a service or host goes
down; even though I specfically set notifications_enabled 0.
Here are my current hosts and services files in case something in
there causes the log rotation to mess up :
Hosts file :
# Generic host definition template
name generic-host ; Name of
template.
checks_enabled 0
flap_detection_enabled 1
process_perf_data 1
retain_status_information 1
notification_interval 60
notification_options n
notifications_enabled 1
register 0 ; Template only. Do
not register
use generic-host
host_name host1
alias host1
address 192.168.x.x
Services file :
name ping
service_description PING
is_volatile 0
check_command
check_ping!1000.0,75%!2000.0,100%
max_check_attempts 3
normal_check_interval 2
retry_check_interval 1
active_checks_enabled 1
passive_checks_enabled 0
check_period 24x7
parallelize_check 1
check_freshness 0
process_perf_data 1
contact_groups dragon-admins
register 0 ; Template for ping
service
# Ping service definition
use ping
host_name host1, host2, host3, host4
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
