Tom DE BLENDE (GCC) wrote:
> Hi,
> I thought I just mention that over the weekend, the Nagios 2.0a1
> installation I'm running was starting to take up a lot of system resources:
> 13:21:54 up 17 days, 4:15, 1 user, load average: 2.66, 1.92, 1.89
> 268 processes: 261 sleeping, 7 running, 0 zombie, 0 stopped
> CPU states: cpu user nice system irq softirq iowait idle
> total 19.2% 0.0% 20.5% 0.0% 0.0% 1.4% 58.5%
> cpu00 17.4% 0.0% 23.2% 0.0% 0.0% 1.5% 57.7%
> cpu01 21.0% 0.0% 17.8% 0.0% 0.1% 1.3% 59.4%
> Mem: 1028544k av, 693836k used, 334708k free, 0k shrd, 213848k
> buff
> 339560k actv, 69812k in_d, 9512k in_c
> Swap: 2044072k av, 31252k used, 2012820k free 156852k
> cached
> PID USER PRI NI SIZE RSS SHARE STAT %CPU %MEM TIME CPU COMMAND
> 12226 nagios 25 0 -12M 0G -18M R 0.5 1670289.6 94:53 0
> nagios
> Restarting the process. Solved it for now. Tell me if you want me to do
> any sort of testing if you think it can be of use for the development of
> Nag 2.0.
This is the embedded perl thingie at work (it seems perl can't be
embedded properly without issues like this. Apache and mod_perl has the
same problem). Re-compile without it and things should work normally
again (I've been running it for 3 months now, and had no problems what
so ever).
> Kind regards,
> Tom
OP5 AB www.op5.se
Lead Developer
