> Hello,
> Please attempt to fix below, maybe we gonna have some problems ahead
> commands.c: In function ‘cmd_signal_process’: commands.c
> warning: assignment makes integer from pointer without a cast
> [enabled by default]
> Looking to the code, schedule_new_event() returns a pointer to a
> timed_event structure or NULL in case of errors during malloc. As
> cmd_signal_process() returns an integer, i've made a patch to analyse
> the return of schedule_new_event() and give the appropriate return
> code(ERROR || OK).
> As I've also seen, we are using cmd_signal_process() only once, and
> it's inside commands.c. The funny thing is that we don't check for
> return code when we call it
Rghto. This looks sensible. I'll apply it straight-away.
OP5 AB www.op5.se
on peace.
